Wanted 1988 NA 944 for NASA 944-spec use
Anyone wanting to sell there 88 944 ? I want the 88 for the short 5th gear and higher power. I live in Denver but will fly out to drive yours back.
please send details to svochuck@aol.com
thanks
chuck
#67 944-spec
thanks
chuck
#67 944-spec
Chuck the 924S (both 87 and 88) had the short 5th. Only the 88 (924S and 944) had the high compression pistons.
Based on all our many 944 spec races the short 5th is needed at any track where you would use 5th. The 88 motors however have not proven to be must haves. In fact I have an 88 motor in my garage. I ran it in my 944 for a few races and noticed no differece in HP. Sadly it spun a bearing so it went to the build stand and my trusty 84 block/87 head motor when back in my race car. I feel I am at NO disadvantage with that motor compared to any 88 motor. However my 88 motor is NOT for sale as it is my spare just incase.
Bottomline.... GET the short 5th! Don't worry about the 88 pistons.
As far as I know, the 88 944 has the high compression piston but both the 87 and 88 924S have higher compression pistons and all 3 also have short 5ths. I am not sure why the high compression motors are not faster but the 88 *should* be faster if built properly since I have not seen a slower car from higher dyno numbers unless these lower compression motors have something done to increase their HP.
So, to recap, the 87 944 and the 87 924S use the same engine, a lower compression M44.07 in the USA.
The 88 944 and the 88 924S use the higher compression M44.08 in the US.
All the 944 NA USA cars up to 87 used the taller 5th gear and the 87-88 924S/944 and the 89 944 had the short 5th gear.
You could (and should) look it up for yourself.
hmm my august 87 924S actually has the higher comp. pistons and its the origonal motor for the car, might have just been a fluke tho or because it was right before they started the 88 run.
Can't use an 89 for spec because of the 2.7 engine.
Why now power gain? Not sure I don't feel over matched in my 9.5:1 motor. Heck I have that 10.2:1 motor collecting dust. It will probably go in in one day, but I am in no rush.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
What I remember from the factory workshop manual for the 944 (which I don't have with me) is that ROW transmissions have short 5th, and there is a footnote that says all (inc US spec) 1988 944 carried ROW transmission. I don't have a workshop manual for 924S, but does it say somewhere in there or elsewhere that 1987 924S also carried ROW transmission or something?
Originally Posted by josephsc
Specifically: how do we know that the 1987 924S had the short 5th?
I know because I am running an 87 924S tranny in my 944 spec car now.
The only way you don't have the short 5th is if the tranny was swapped before you bought the car.
