Wiper Motor Replacement
Wiper motor that I just bought came in yesterday, after driving in rain for the past 2 weeks without it working. Wake up today, and its beautiful out.
Anyway, when I got the cover off,water was all around the fuse box, and surrounding the motor.
I had no idea that there was water building up there. If I change up those motors, will the same thing eventually happen to the new one?
Anyone else have this much water stay in there when it rains? A drain plug I'm possibly missing?
Drain hole plugged
If you look to the right of the fusebox there is a drain hole this will get filled up with leaves and crap you may have to feel along the bottom for it. clear away the debres and the water should drain. Hope this helps.
Mark
Mark
