turn signal flasher
turn signal flasher
My turn signals became intermittent, all the bulbs light normal, just don't flash.
I pulled the flasher relay out and removed its cover, put it under a microscope and the contacts are practically gone. One had a hole burnt all the way thru the center. Luckily the locals have it in stock for less than $ 10.
Talking about turn signals, did someone ever do this, I want to install a buzzer that will sound when the turn signal is on. I want to do this because I have a Momo stearing wheel and I was told that it does not have the release to remove the signal after a turn, so I keep forgeting to remove it
Anyone done this and explain how they did it?
Stephane
Stephane
