Brake Fluid Leak
Brake Fluid Leak
I just discovered the source of a recent brake fluid leak. Its forming around the o-ring in the pic and running down onto the frame and exhaust. Can someone suggest the best way to fix this problem. Tightening it was no help.
PET identifies the part as the brake pressure regulator, which I assume is the same thing as a proportioning valve? Does anyone know if you can just replace the O-ring, or if you should (or have to) get a new part if it starts leaking like this? Also, are there any other options out there, like one that is adjustable, etc.?
