Toyota 4runner question
I know this off topic, but I can not get to the Off Topic anymore and this forum seems to have all the answers anyway and I need an answer. By the way, I apparently let my membership expire, I will be renewing when I get home, so you do not need to tell me to become a member.
Has anybody replaced a timing belt on a 99 (3rd gen) 4 runner V6?
If so, what did you use to compress the tensioner?
Once again, sorry for the off topic.
Thank you
Tom
Thank you
Tom
I had a 97 4runner I changed the timing belt on. The tensioner is a hydraulic tensioner. Without the special tool, remove the entire tensioner assembly and compress the hydraulic piston in a vise. Once compressed put a paper clip in the hole to hold it in. Put the tensioner and timing belt back on and pull the paper clip out.
It's been a few years since I did it, I think that is all there was to it.
now about that membership
packrat,
Thanks for the suggestion, I'll probably go down that path with it.
I should I have the red letters under my name very shortly.
Jake,
The 4runner is actually a friend's of mine. After he saw what was involved with replacing my Passat timing belt he thinks I can do anything.
For those who don't know, to replace a timing belt on a 1.8T Passat you have to move the entire front clip of the car forward to have enough clearance to get at the belt. I choose to just remove everything so I had lots of room. He saw the pile of parts that included a radiator, bumper cover, metal bumper underneath, headlights, the grill and then of course a big bucket of fasteners.
Thanks again
Tom
Jake,
Thanks again
Tom
