*Help! Need a Clutch Housing*
Hello all, I am in the midst of doing a clutch change (for the 2nd time due to slipping Kevlar disc) and I am in need of a clutch bell housing. Mine is craked right around where the clutch fork guide pin goes up into the housing itself and inside the housing as well. When I was putting the clutch in the first time I was torquing down that stop bolt and nut for the pivot pin and *Crack*. I was using the torque value per the factory manual and a calibrated 1/4" torque wrench while going slow.
This is a NA bellhousing I am in need of. The car it is in regards to is the Callaway 944. I am stepping up to a full-face Feramic disc with my +30% pressure plate. Disc is from South Bend Clutch Co.
I seen a couple on ebay but I wanted to see if any of you had a spare lying around. TIA!
I have some laying around. Drop me a line with a offer with you paying shipping
toddandcharity@bellsouth.net
