Started and then died -0PSI ON ALL CYLINDERS, and then Runs now
Lazer Beam Shooter
Well I just checked the timing, lined the camshaft mark up then checked TDC in the flywheel hole, nowhere to be seen. Then looked in the starter hole, nowhere to be seen. The belt had perfect tension though, and was probally overtensioned a little.
There went my last 944
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
well the mark goes by pretty fast. are you doign it all yorself? arent there a good bit of rennlisters in va to help?
my girlfriend at the time stopped helpign me look for the line, but i was able to get the wrench, turn it, laying on top of the engine/fender, lookign for the timing mark on top with a flash light in the winter. if i remember correctly, youre a little taller than me, so id think you might be able to do this also, but maybe with less stretchign to the ratchet on the crank.
take all of your plugs out so (just in case) the compression wont make the crank want to pop over and be easy, then pop over, or more than likely youll miss the mark.
i think it was andy and john"special tool"(hasnt posted for a while) that told me to have the line sitting on TOP of the pointer in the bellhousing, and about 1.5 before the pointer on the cam housing.
hopefully youll get it figured out without too much money/work.
Rock,
Have you heard of the pencil test? You stick something down the #1 cyl plug hole and make sure that it is at the top of it's rotation. Nice way to double check things before you get too far in. When re-building the '83 Eric and I had a hard time finding the timing mark on the flywheel so we set things by using the pencil test THEN we were able to find the mark.
Michael
Michael
I would re-do the compression test, just to be sure.
However after my timing belt slipped, and I bent the valves, my compression test was zero.
This is all on the 2.0 though. But try re-doing the compression test.
Lazer Beam Shooter
Ive rotated it around like 10 times, it is definitly WAY off I dont know how the hell that happened.
The car started and ran for like a total of 3 minutes.
Im fooked
Im fooked
Originally Posted by MPD47
Rock, rotate the engine another 180 degrees. Two rotations of the cam for every one of the crank. Then check again.
I think you're just doing the compression check wrong, unless the above isn't true. Then you're dooooomed.
____________________________________
1986 944 NA - Guards Red - 88k miles
1983 944 NA - Platinum metallic - awaiting new engine
1985.1 944 NA - Guards Red - donor car
1984 911 Carrera Coupe - Guards Red (gone, but not forgotten)
"If you're not living on the edge, you're not living"
