924s M030 question
924s M030 question
Hello, I have just purchased a 1988 924s SE. I have been doing some research on the car and have discovered that it has the M030 suspension. While researching the car I have learned that the car has adjusable spring perches in the front to allow for corner balancing. I have also heard people talking about the car having adjustable shocks. Is the compression/rebound adjustble on the shocks or were people just confusing adjustable shocks with the threaded lower perch? TIA
I think in this case the car you have has adjustable rear shocks not threaded collars. As in the twist and shout style
Front I think has adjustable rebound on top along with collar for spring.
Been a long time since I played with one....
http://www.koni-na.com/adjustment.cfm
