anyone know what the bolt measurments are on the AC to bracket?
since we are speaking of previous owners, its been warming up here so turning the ac on my belt has started squeeling when the ac clutch is engaged, i go to tighten it last night and see that the rear of the ac is loose. the PO riged a bolt up through the front that sticks out about 3 inches and doesn't attach to the back, would anyone happen to know the bolt size that connects the compressor to the ac bracket?
Herr Unmöglich
I did a quick measurement as I ran out the door this morning. There are two longer bolts and two shorter bolts for the stock A/C bracket. The longer was ~80mm long, and the shorter ~60mm.
I removed the A/C and have a billet bracket coming to mount the alternator in its place. If you want I'd be happy to send you the factory bolts from my A/C setup... everyone here has A/C already so it's not as if there is a large market for A/C mounting parts
Also if you need more detail I can mic and photo the pieces when I get home tonite. PM me with your info if you want my factory bolts.
