Koni Settings
Koni Settings
I am using my Konis to autocross for the forst time tomorrow and am wondering what that best settings would bt. I am running 19mm adjustable sway in the rear on thi middle setting with a 26.8 mm bar in the fron. I have the rear shocks set to medium. If the ground is dry I will be using my Kumho Ecsta V710 tires if wet using Fuzion ZRi. What should I set the front struts at? I have been driving around with them full stiff.
