Anyone ever installed a headlight relay cover??
How the heck do you install these things? (getting the headlight motor power plug through the boot-like thing on the relay cover?)
You need to get a pin extractor. Make sure to disconnect the battery because the relay control is always hot.
The only other way is to get a new plug, cut the pins out of the old plug, install the new boot, and then put the pins in the new plug.
