944 Turbo Fog Lights
Guys. I know somewhere I saw directions on how to change out the light bulbs on fog lights for a 944 Turbo, but I can't remember where. can someone please send me a link?
Thanks,
Chris
Thanks,
Chris
WOW, this is EASY, I can take this one guys! Ok, so looking at the fog lights you see the two plastic sides that have screws on them, remove. You then will see 2 more screws to remove to get the fog likght out, remove. After that, the whole fog light unit will come out but still connected by the power. When you pull out, you can then see how to get the bulb out and replace. Couple of pointers first off, make sure you use stock wattage because you don't want to overload the system/wiring. When tighting down the screws to the unit or plastics pieces, be sure to just snug down, don't want to strip them. Other then that, pretty straight forward and easy, good luck!
