Engine is missing under load
While accelerating in low RPM at top gear or going up hills, just tonight my 924 was having a terrible time. The RPMS would stay the same, but the oil pressure would take a hit and the car would jerk or chug.
I run 91-93 octane fuel, my car is a daily driver. It has needed a fuel filter for awhile and the plug wires are probably original (new plugs tho) but I'm on a buget, I want to fix the problems as they come along... any ideas what the problem is?
Originally Posted by F18Rep
I think you're thinking right with the wires. Start her up and peek under the hood while it is dark. Once your eyes adjust you might see the arcing - its worked for me. Bruce
It may also be an injector, my car has a nice diesel like chatter to it.
If the problem was secondary ignition, the oil pressure wouldn't drop. If it was a voltage issue, then I'd think all of the guages would go bonkers. Maybe a oil level or pump pickup issue activation the low oil pressure safety switch? This would also fit acceleration/uphill as rearward slosh could interrupt pump supply.
I'm not that familier with 924's so if this doesn't fit, maybe someone can correct?
Good luck,
Bill
Good luck,
Bill
Good luck,
Bill
Good luck,
Bill
When I had the car up on the jack and started it on the new oil change today, it worked as it should (built almost immediately even with a dry filter).
However, the front of the car was elevated and the front is also elevated when going up hills.
As far as 944's and 924's, they had identical engines I believe...
