Upgading to later E-brake?
I've been considering upgrading to the hand brake handle from a later car. I've heard that they don't break as much. Is this true? My hand brake isn't staying up because i guess I pulled it too hard. Fixed it once before.
I've changed ALL my early cars in my sig. to the "later" handles. I like 'em better. JUST remember, if you get a later handle, also get the switch mount for it. THEY, are different. You'll need it in order to get the switch to work properly due to the curvature change.
Under the Radar
I did this upgrade in January. It's the perfect time to get the parking brake adjusted the right way.
One thing: The bracket should have a slight u-shape when mounted. It took me two hours to figure that out, since the plunger switch on the bracket I received was mounted upside down and it wouldn't mount properly. It sounds strange to read that, but you'll understand if you decide to put it in.
