Where to buy jack stands with flat top?
I have two sets of jack stands with the tops that look like claws. They did into my car whenever I put the car up on them. I have been looking for jack stands with flat tops, and I have had little luck. A company called AC Hydraulics has nice ones for $100 each. I'd rather put the $400 toward purchase of a lift! Anyone know of more "economical" jack stands with flat tops??? Maybe the best bet is to take mine to a welder and weld flat tops onto the claws?
Mark
Mark
They don't have flat tops so that your car doesn't slide off. Do a search for jack points and you should be able to find a diagram of where to place the jack stands. You shouldn't have any problems with them digging in if you are using the right locations. I never had problems once the car was jacked up. Now jacking the car was a whole different story, You may wanna use something like what Automotion sells:
http://www.automotion.com/productpag...ds&part=121601
Michael
Michael
Mark
Mark
I don't use no stinking jackstands.
95% of the work you'll ever do, you'll only go 2 blocks high in each corner. Any higher, and you'll need a long frame jack to get the car up that high also.
Concrete blocks, cost........$1.69 each. 12each blocks, about $22.00.
Na, each of those blocks is rated for at least 1000lbs.
Now that being said he is really not using 12 but 4 as the surface and the base are distributing the weight the same. It is a better footprint than a standard floor jack stand but as others have mentioned it is a stone/cement based material and I would be a bit concerned if it began to fracture and/or crack. Definitely check BEFORE and after EVERY use. If there is any problem, go and add it to your "this old house" project.
Nice car Ken![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Michael
Nice car Ken
Michael
Make sure you get solid cinder blocks if you're going to do that though. The hollow ones are a piece of cake to chop in half. Easier to break then 1/2" wood...but a bit rougher on the knuckles.
Pep Boys carries a aluminum race jack that come with a pair of 3 ton aluminum jack stands with flat tops. The jack has a max height of about 17.5 inches and I think the jack stands are about 15.5 inches. Last year I think the price was like $179 for the jack and stand kit , who knows maybe they sell the jack stands seperately.
Good luck
I did a google search and came up with this
http://www2.northerntool.com/product..._200313355.htm
wow. yea. cinder blocks probably crumble like nothing if you get at em the right way.
its like duct tape. cant pull a piece apart if you're the strongest man in the world
but a mouse can tear a piece sideways
Yeah.. i have my parts car on cinder blocks.. iw as undoing an axle nut, and one of the stack of blocks just crumbled into nothing.. but i only had a piece of 2x4 between the car and the block maybe thats why.
I've done quite a bit of work with the car on jack stands. Getting under a properly supported car is probably less dangerous than driving to work. That being said, I don't spend any more time under the car than I have to. Right now I need to work on the brakes, including new brake fluid. So, I don't really need to get under the car, I just want the four wheels off the ground.
Those Torin stands look like they will do the trick. Sorry, but I just don't like the claws.
Thanks for all the input,
Mark
Mark
I took 1/2inch thick pucks of round steal and welded them to the tops of my jack stands and then welded in the pins that hold them into the jacking points works great cost about 5 dollers.
