Had to let my Baby go!!!!!!!!!!
I am sure most of you have seen my other post about my 83 944. Well i knew what i was getting into when i got her, but she was my daily driver and becomeing a reliability issue.
So i had to make a decision. I went down to the dealer and found a 03 Jetta Gl 1.8T. I was going to try and keep my 944 but ended up needing to trade her in so i could get my payments where i could afford the jetta and the suburban. To my surprise the dealer gave me a thousand more than i paid for her originally. I am still in the hole on her but i still made out pretty fair.
Between now and and next spring i will be getting another 944 or hopefully a 951. I drove jeremy's 951 and fell in love. Till then i do still get to play with boost on my jetta. I will post pics when i get a chance. Does anyone know of a good VW forum that i can check out. I want to see what kind of mods i can do to my 1.8T.
I will still be lurking here on the best forum on the net. like i said, I am going to get another 944.
I was just passing through the rennlist forums and saw that you needed a good volkswagen forum... vwvortex.com is the best I know of...should be tons of information in the MK4 and 1.8T forums for you
Cool deal man. I will check it out.
Dale
Nerd Herder
You'll be back. Porsche's are like Crack. Once you are hooked, you'll spend thousands of dollars on your habit- You cant kick this.
Best of luck with the VeeDub!
Oh i know i will be back. Most likely with BOOST.
Dale
