Hard left + accelleration = grinding noise (sometimes)?
Old 04-12-2006, 11:13 AM
AndyK
AndyK's Avatar
Default Hard left + accelleration = grinding noise (sometimes)?
Sometimes, when making a sharp left, and hitting the gas, I get a grinding, vibration type noise--I think from the right rear. Doesn't happen all the time though.
Could it be CV joints? Or something else?
Old 04-12-2006, 11:15 AM
Z-man
Z-man's Avatar
Andy -
Yep - could be CV joints - when was the last time they were looked at?
Could also be a rear wheel bearing. Slight chance. I would check the CV joints first. Check the condition of the CV joint boots for cracks and tears.
-Z.
Old 04-12-2006, 11:18 AM
AndyK
AndyK's Avatar
Originally Posted by Z-man
Andy -
-Z.
Not sure if these are originals or not--bet they are though! How tough a repair is it to replace the rear half-axels--if that's what I need??
Old 04-12-2006, 11:27 AM
pcarfan944
pcarfan944's Avatar
Mine does the same thing, only when turning left while accelerating except the noise is coming from the front somewhere. I've been wondering about it for a while so i'm glad you asked.
____
Pat
86 944
95 Audi 90 CS
Old 04-12-2006, 01:41 PM
Jaay87S
Jaay87S's Avatar
I can attest to the same problem too... guess it's somewhat common. Anyone know how critical it is to address this problem?
Old 04-12-2006, 06:12 PM
Dal Heger
Dal Heger's Avatar
Actually I found it to be the tire rubbing on the inside of the fenderwell. The suspension is soft enough that it happens from time to time, especially if you fitted a bit wider than standard tires.
Check the simple things first.
Doubt that it would be the CV's - they click
Doubt that it would be the bearing - that sounds different too. You can tell if it's a bearing by doing a nice little slalom with the car, the sound will change as you load/unload the bearing in question.
Dal.
Old 04-12-2006, 06:37 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,127 Likes on 807 Posts
Make sure the dust sheild is not too close to the rotors, I concur on checking the the simple things first.
Half axles are easy ... just messy. you can get a boot kit which includes boot grease and clips, but unless you are really cash strapped replace the cv joint and be done with it ( ps mine clicked )
Old 04-12-2006, 07:08 PM
AndyK
AndyK's Avatar
I would just buy new (or rebuilt) half-axles...no way I'm killing myself ripping the old ones apart!
Tires are stock width, and I doubt my new Koni yellow's are letting the tire hit the body...?
Old 04-12-2006, 10:16 PM
Dal Heger
Dal Heger's Avatar
I don't, happens to mine. Stock torsion bar == SOFT.
Seriously doubt that it's the halfshafts.
But take my advice and use your own judgement.
Dal.
Old 04-12-2006, 10:20 PM
pcarfan944
pcarfan944's Avatar
This might not make sense....but with my car, I notice it does it a lot more once i've been driving a bit and everything is warmed up, and it really only makes the grinding sound between 2800-3200 rpm.
_____
Pat
86 944
95 Audi 90 CS
Old 04-12-2006, 10:45 PM
gtroth
gtroth's Avatar
Yeah, CV's thump at a once around frequency of the rear wheel in my experience (i.e. the one time I had one quit). Left side would more likely be the one to go first, I think, due to exhaust heat.
If you replace the axles anyway, it's not too difficult. Use PB blaster, clean out the socket heads real good, wake up the bolts, and use a good cheesehead tool. And torque them right when reinstalling.
Old 04-12-2006, 11:12 PM
Oddjob
Oddjob's Avatar
Grinding noises during turning are more commonly wheel bearings or exhaust rubbing. Tire rubbing can also give somewhat of a grinding feel or sound. Its more typical for CV joints to tick or give a rythmic thumping than a grinding noise/feel.
Old 04-13-2006, 09:36 AM
AndyK
AndyK's Avatar
Hmmm. It does sound like the exhaust vibrating, when it does happen. Could be a heat shield or something like that. It's not a ticking sound--more like a vibration.
Old 04-13-2006, 09:39 AM
Chris_924s
Nerd Herder
Chris_924s's Avatar
I had a grinding from the front at a 1/4-1/3 wheel turn sweeping right. 15-35 mph only.
It was the front wheel bearings.
Check for excessive front wheel movement while in the air.
Exhausts rattle, not grind. (mine was at 2900rpm.) That noise made me frikkin crazy til I got the damn rattle fixed.
HTH
Old 04-13-2006, 10:03 AM
Oddjob
Oddjob's Avatar
HTH
Depends on where the exhaust is rubbing. It rattles if something is loose or if hitting something that is not solid (like a heat shield).
But I had my exhaust (down pipe section of a turbo exhaust) rub on the control arm caster mounting point only during hard right hand turns while under acceleration (combination of the body flex and the motor mount deflection while under load). The exhaust is very solidly bolted in place at that point, and it was pushing against the solid frame of the car - sounded very similar to a bad wheel bearing.
Quick Reply: Hard left + accelleration = grinding noise (sometimes)?
