Suspension Gurus please advise
Took the car down to the local alignment shop......
Advised to me that the camber on the left front is -2.6 and -2.7 on the right. The tech said the computer shows there should be about -0.8 camber and he could not adjust the camber back to this spec.
Can this be adjusted or is something broken or need to be replaced?
Here are the current specs:
Left Front - Camber = -2.6, Caster = 2.5, Toe = -0.05
Right Front - Camber = -2.7, Caster = 3.4, Toe = -0.08
Total Toe = -0.13
Steer Ahead = 0.02
Left Rear - Camber = -0.7, Toe = -0.40
Right Rear - Camber = -0.6, Toe = -0.04
Total Toe = -0.43
Thrust Angle = -0.18
This is a street car so what should the numbers be?
Total Toe = -0.13
Steer Ahead = 0.02
Total Toe = -0.43
It is going to eat up the inside edge of tires is what it means. Is your car lowered?
You also needed to have the rear toe adjusted.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Originally Posted by Matt H
It is going to eat up the inside edge of tires is what it means. .
I should have been more specific.
What I am wondering is if the large negative camber means something may be broken. Or is it possible the PO intended this much camber? Should a shop be able to put the camber back to "street" spec?
Yes, it is possible that they wanted that much, makes for a nice semi track setup. The struts have eccentric bolts for adjusting it, it should be able to be adjusted.
