Header Panel and bumper cover bolts/hardware
I have managed to lose some of the bolts needed for the header panel. Does anyone know what sizes/part numbers they would be? Same situation for the bumper cover.
Thanks in advance,
Eric
Thanks in advance,
Eric
The rear bumper has 13mm bolts, 2 at each bumper shock, that bolts to the rear frame crossmenber. The Bumper extensions ( side pieces) are held on by 3-4 8mm nuts into the rear qtr panel. It is easier to remoove the bumper by this methof. If you remoove the rear bumper at the 2 allen head bolts you will have to realign the bumper.
No knowing the year and modle, The early cars need to have the spot welds remooved. The later cars are as follows.
1. remove the 4 philips screws across the top, underneathe the hood opening.
2. lift the headlights, use a dull flat blade to pry out the rubber gasket just behind the thin strip of the header
3. underneath that is 2(8mm) lock nuts
4. last there is a 10mm on each end of the thin scetion of the headter panel where it meets the fender, it goes into the end of the fender, pointing outwards.
I hope this helps. you can also do a seach, had been covered here before..
