How do i remove the head, turbo, dme and nose from 931
Old 03-29-2006 | 11:01 AM
Royalty's Avatar
Royalty
Question How do i remove the head, turbo, dme and nose from 931
Hey yall. I got a 931 tubo that got hit so its going away.
I wanna get the head, turbo, dme and nose off of it. I looked at the garage shop manual but it counldt help me too much, i have a strange model.
1. The nose - it seems liek its tack weleded on and the only way I can get it off would be to cut it off. There are no screws liek there would be on a 951.
2. the head - it may be simple but I'm not sure. i got the valve cover off but thats about it
3. dme, whre is that lil bugger?
4. the turbo - I'm under the car and i see it. i beleive th conrtol arm is in the way. I coudl unbold the exhaust but there it a bot on top of it that i KNOW i will not be able to get to.
Or possibly would it just be easier to take the head off and then get to the turbo?
Old 03-29-2006 | 11:13 AM
924RACR's Avatar
924RACR
I'd recommend by far pulling the engine complete - much easier. Getting the turbo out will take longer, not to mention the head.
The nose panel is welded on, correct.
Engine control units are inside; one under the steering column (Lambda control) and the ignition controller on the center tunnel under the HVAC unit.
Old 03-29-2006 | 02:30 PM
Techno Duck's Avatar
Techno Duck
The nose panel is spot welded on aross the top lip (which is covered by the hood when shut) and along the bottom, i think you will need to remove the bumper and work on your back to drill out the welds along the bottom edge, there are a fair amount of them also, i think i remember about 15+.
Quick Reply: How do i remove the head, turbo, dme and nose from 931
