Brake problem
i should also add then when I pump the brake it comes up (engages higher), but not as high as it used to. My mechanic checked the brakes and said everything was installed correctly so I assume all the clips and retainers are correct.
Originally Posted by AR10
Something is causing the pads to need to move too much to touch the
rotor on one or more wheels.
