O2 sensor necessary on an '84?
My '84's O2 sensor was disconnected by the PO. The mechanic that did my PPI told me that the early cars tend to run better without them. Car runs fine. Thoughts?
well i kno that if you plan on passing a state emissions inspection, it better be hooked up. otherwise i cant be of much help. I am pretty sure that the O2 sensor takes in whatever data it can from the exhaust, then sends this back into the computer to tell it how much gas/air needs to be in the cylinder on each combustion stroke (tells it to run more lean or rich).
Not good configuration. If You want to get rid of O2 sensor, then You should configure DME to ROW (rest of world) mode using configuration plugs - see repair manual. Big diference in performance and culture of work of the engine.
My understanding from poking through F R Wilk's site was that the O2 sensor had a very limited affect on the air/fuel mixture - it only "fine tunes" the mixture to help meet the emissions regs. The DME primarilly uses the air flow meter and engine speed to set fuel mix according to internal maps. Check out the "lamda inside" section of his site. It explains things pretty well, although it does get a bit technical.
The O2 sensor keeps the A/F ratio dittering around 14.7/1 to allow the cat to work correctly. Remove the cat, might as well remove the O2 sensor. The Porsche 944 manuals show you how to switch to ROW.
