UGH NJ EMISSIONS!!!
Dark sooty exhaust means you are running rich. It will also make your eyes tear if its real bad. I think we established the fact you are running rich...you just need to figure out why now.
You said you put on a new FPR, did that solve the problem?
Getting the old O2 sensor off can be a real pain in the ***...i reccommend running the car up to temp, shutting it off. And spraying the hell out of it with a penetrating oil. Mine took a fair amount of penetrating oil and ALOT of force with two wrenches to get it off.
You can tell that the car is running better. But it did sputter and stall again tonight. It didnt sputter for as long but it did still stall when the car was pulled to a complete stop.
The idle doesnt vary as much and it is a little more responsive to throttle, but both are still below ideal. Slightly unresponsive but not as much as before.
Would the AFM make it sputter and stall?
-Brett
-Brett
Originally Posted by Calmchaos
I just ordered a new FPR since its only $65. I'll put it in ASAP.
Is this probably why my car starts supttering and stalls out on occasion? And then runs fine after I blow it out.
My spark plugs are brand new NGK Iridiums.
I had a similar symptom with my turbo charged motorcycle a few years ago. The plugs would foul up rather quickly and it was hard to keep it running after starting unless I revved it up a lot. I also couldn’t drive slowly without it fouling up the plugs and running like you are describing. It turned out to be the spark plugs even new ones would foul quickly. I changed to a one number hotter plug and the problem went away and hasn’t come back.
It may be something as simple as the wrong spark plugs. Do you still have the old plugs that you replaced? If you do try putting them in and see how the car runs.
