Rear wheel studs removal - help needed.
Ok, how do I remove rear wheel studs? I'm trying to put longer ones. I can't take off that plate that holds them. Any ideas anyone??
I have - put some monster studs on the back of the racecar for all the spacers. I was not able to remove the old studs without removing the hub, as I recall... but yeah, after removing the hub nut, it should more or less come right off. Maybe some corrosion/sticktion holding it on?
You could try putting the wheel back on and yanking on the wheel?
