Part Needed
Got Nothin'
Guys -
Need the surround for the switches on the door of an 86 944. Don't need the switches, just the surround.
Also need the black trim that holds the clock, lighter etc on the dash. The tab on the end near the climate control broke (second time)
Thanks for the help.
I have the strip.. but the peice that holds the hazard in, those two real thin little tabs broke.. If you want to like epoxy your hazard switch in there it would work fine, or expoxy the two tiny little tabs on.. They are so small and thin, they were destine to break. The front of it is perfect and once it is installed you will not be able to tell at all.
-keith
-keith
