Shifter Rattles
Hi Gang,
My shifter vibrates and makes noise when I'm in gear. It seems like the damping material below the shift boot has worn or disappeared and I'm getting metal-to-metal contact. So, before I start taking apart my center console, what can I expect? What part would I need to order (new or used) to solve the problem?
Thanks,
Paul
Thanks,
Paul
You can check the situation out by just pulling up the boot frame and inner bellows. The peg off the lever wears over time which results in slop. If the washers are missing it might buzz.
Yep, if it becomes worn enough, it will be loose even in the middle (usually the fattest part when it wears). If it's loose there it can/will rattle.
I've had 2 do that before, both my 86 and my 87.
Hey Man
Originally Posted by pcutt
Thanks for the info. Now I have a better idea of what to expect between now and Saturday when I can do some wrenching.
