Brake caliper mounting bolts, 944 Turbo rear and N/A front same?
Can anyone verify if the caliper mounting bolts for the FRONT of the n/a are the same as the REAR caliper mount bolts for the 944 Turbo? PET lists the bolts as being the same, however PelicanParts lists them as having the same dimensions, but different part #...? I would tend to trust PET, but maybe Pelican knows something we dont.
PET listed the bolt, which is M12 1.5x40 as part # N 040 108 1
Pelican lists the bolt as the same dimension as part # N 040 108 2 for the front N/A caliper and # N040 108 1 for the rear turbo calipers. The price difference is large also, the front n/a bolt being $7.70 and the rear turbo bolt being $1.50
I am going to try and swap to the 944 Turbo calipers this weekend, its the only weekend i have to work on the car and get an alignment done before autocross starts. In which case i wont be able to get this stuff done for another month or two. PelicanParts however cannot source two more of the rear caliper mounting bolts, i have no clue when they will be able to get more in stock.
