Installing Front Speakers
I'd make a pictorial out of this, and had planned to until I realized the Blau's I bought would fit a car with power windows, without any shims, etc. The Blaupunkt PCxb46's were purchased about 3 months ago and now its the rainy day to install them. I had originally yanked the stock speakers when I bought the car, they had either dry-rotted from moisture, if thats normal for 10+ year old speakers, or possibly water leaking into the door from faulty window scrapers.
The original speakers were mounted in between the black plastic mount for the speaker grill and the grill. There was no protrusion, the center of the speaker was no more than 1/16" in. from the actual mount on the speaker, so the grills fit on perfect. Well, I tried doing the same thing for these, figuring mounting a speaker to bare metal might give unwanted side effects and some distortion but on the Blau's the center is about 1/4" from the rest of the speaker. I can only formulate that the speaker is supposed to be mounted to the door, then the speaker mount and grill go on top. In this case, should some type of rubber washer be installed between the speaker and door?
As far as moisture problems, has anyone gone so far as to install a baffle to protect the speakers, or am I just being paranoid. The door shells are DRY as can be on the inside, I have no reason to believe water is leaking in. I do know Crutchfield sells baffles for a speaker this size, but it might add height and mounting on thick rubber might cause the mounting to look a little off.
You should be fine mounting right onto the metle but just make sure that the speaker wont interfer with the power windows sense its going to be going into the door a little bit further. However if it was me i'd at least make a rubber gasket to go between the speaker and the door to keep it from rattling.
No go. With the speakers mounted and the grill mount on top, the grill won't fit down because the speaker is actually recessed into the door too much. And I wondered why I found one lone spacer on the last speakers.
Nope, which doesn't make sense since theres plastic covering the door shell under the panel. Some sort of moisture guard. I might just buy the baffles and hope those will act as the spacer I need, but it will be a TIGHT fit with the power windows.
Is this on an early or late style car?
I was able to get similar speakers by Blaupunkt to fit into my doors without any problems at all. They are a different model, but look exactly the same and i would bet have the same dimensions. The speakers came with a black plastic spacer. I stuck the speaker into the door, stuck the spacer ontop, then put the stock grill on. Using the supplied black screws (Which were fairly long) it screwed right in without any problems.
Unfortunetley i dont have any pictures of it, can take some tomorrow if you need.
Also the speaker holes have a plastic / rubber cover, this in my opinion is suitable to protecting the speaker from any moisture. Have had them in my car for over a year now and never had problems. Had them in my 924S also, never had problems for about a year also, still never had problems!
