Best torsion bar for 250lbs spring ?
Originally Posted by Frank944
What do you think of the suspension package described here:
http://members.rennlist.com/944sandmore/stick.htm
-Koni's all around
-Weltmeister 250 lb/in. springs
-Weltmeister 26mm Rear Torsion Bars
-Weltmeister 28mm front sway bar
-Weltmeister 22 mm Rear sway bar
-225/50/15 tires on four corners
According to you the rear torsion bars would be too soft and the car would have a tendancy to understeer, am I right? 28 mm would be better, and by the way, what do you think of weltmeister sway bars?
-Koni's all around
I have 225s on the front and 245s on the rear to help to keep the rear in line and I find that I need to run a little more air in the front tires to fine-tune the traction rearward a little more. I also have 968 M030 sway bars with the rear set at the middle position. That gives me some adjustability in either direction, still, although I think the handling is great as it is
I have a friend who has the Weltmeister sways (I'm not sure if they're the same one's in your list) and he thinks they're great. The front one's are adjustable by sliders rather than discrete positions so they can be set anywhere in their range. That's a nice feature for fine-tuning, although maybe overkill for the street. The hardware looks very beefy.
I'm not sure if that helps you any, but there it is
Thanks for your help! I'm presently thinking of a suspension setup for my 83 944 for some autocross, DE and track time and I've got to drive it on streets to get to the event! It has to be ajustable in many ways to ajust it to perfection and yet has to be affordable. If someone knows a winner's setup for my use let me know!
