S2 brembo brakes compatible with 15" dials ?
Old 01-17-2006, 04:20 PM
bleucamaro
bleucamaro's Avatar
IIRC the spare tire on my S2 is on a 15 inch wheel. The car is at home, so I'd have to check tonight. It fits very close to the caliper, and a 15" PD or fuch's may not clear due to the internal shape of the wheel. If aftermarket, light weight 15's would fit, I'd get a set for auto-x wheels.
Old 01-17-2006, 04:35 PM
HughA44s
HughA44s's Avatar
I did this conversion on a 87 N/A (used S2/968/944T) parts and 15 inch phonedials DO NOT fit - had to go with 16s.
Old 01-17-2006, 04:37 PM
tifosiman
tifosiman's Avatar
There you go. Thanks!
Old 01-17-2006, 05:02 PM
josephsc
josephsc's Avatar
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Is that true for both fronts and rears?
Old 01-17-2006, 08:49 PM
bleucamaro
bleucamaro's Avatar
If it weren't, would you really want to run 16" fronts and 15" rears?
Old 01-18-2006, 09:34 AM
HughA44s
HughA44s's Avatar
As I remember, either the front or back did fit, but obviously not both. I think bleu (see above) has the correct question. The point of interference is the brake caliper to the inside ridge of the wheel.
Quick Reply: S2 brembo brakes compatible with 15" dials ?
