Drip Rail Molding Question
Old 01-15-2006 | 07:15 PM
Burma Shave's Avatar
Burma Shave
Default Drip Rail Molding Question
Has anyone removed these? If so, did they come off without damage and do you have any tips? Thanks.
Old 01-15-2006 | 07:26 PM
Peckster's Avatar
Peckster
Drip rail? Wuzzat?
Old 01-15-2006 | 08:38 PM
ELLSSUU's Avatar
ELLSSUU
Geaux Tigers!
Yes they come off with a little pressure. Are held on with removable friction spring like things. The rubber is also replaceble.
Rich Sandor's Avatar
Rich Sandor
they just pop off. use a flathead screwdriver with a rag wrapped around the tip to protect the paint.
Old 01-15-2006 | 08:40 PM
aribop's Avatar
aribop
I find it easier to start at the rear of the rail. To get it started I use a small screwdriver covered with tape so I don't scratch the car. Pry up and it will pop loose. The rest can be manipulated by hand until the rail is free from the car.
Old 01-16-2006 | 12:51 AM
Burma Shave
Sweeeet. Thanks! Soon to be shiny again :-)
Old 01-16-2006 | 01:04 AM
nine-44's Avatar
nine-44
Once you get the rear clip poped, use a small flatblade to push down the others, they will "unlock" You'll see when you get in there.
