Please CHECK YOUR MAIN GROUND
UAE Rennlist Ambassador
Mike, that is exactly how mine looked like, and thank goodness i got Dan's kit to replace it with.
You think the main ground is bad? take a look at the positive cable
Originally Posted by sh944
The series I 944's ('83-85.5) did not have an insulated ground wire for either the battery ground or chassis to engine ground. The series II car ('85.5+) did have insulated ground wires.
The main problem with ground wires is that over time, the resistance in the cable will go up. And as Perry can attest, unattended power cables, particularly the one that runs down to the starter, insulation cracks can lead to the hot lead grounding out, causing electrical component damage and possibly fire.
Regards,
Regards,
Yep, that ground wire IS cracked up. Is it a hazard? NO! The only real issue with that one, is corrosion intrusion on that wiring. NOW, like Perry said above, the REAL concern would be IF the Positive battery cable looked like that. THEN, you'd have a fire hazard from shorting out, and reason to be VERY concerned. Good to get it repaired or replaced however. The real key to these cables is the loss of resistance going under the battery post to wire connection, and or the lug connector on the other end, as you can't really SEE that part well. Look for trailing green corrosion from connectors, and R&R those fittings if ya see it, and don't have the ability/tools to check the total ressistance value in those cables from end to end. I've been meaning to acquire or make up some ground cables of that type to put on my early cars. That way, there is a more direct connection between the ground post on the battery, and the engine. I pretty much install #4 cable from the chassis to the upper balance shaft front bolt anyway, so not that big a deal. Just my .02. Good find, and checkover!
Just noticed something. Kinda off the wall, and no harm intended, but did make me chuckle when I noticed it.
ehall,
in your sig. You have......"You can discover what your enemy fears most by observing the means he uses to frighten you. "
AND, under your avatar you have for location.........."You're in my crosshairs"
Does this mean..............your afraid of being SHOT?.............
Just kidding! You SURE are not an enemy of mine! JUST made me CHUCKLE!
ehall,
ehall,
ehall,
that spot used to contain my hometown. Not so much now. What I put there was, I guess, more an expression of the sentiment I was feeling about this at the time of the change. It is my nature to be the hunter,rather than the hunted.
The quote is from Erik Hoffer, who route a definitive work on the anatomy of mass movements. The book is called The True Believer. I think it is INCREDIBLY relevent, and essential reading in the current World climate.
So there you go. If I told you what I did fear, I would have to become an American Christian Religious Zealot to defeat you.
Originally Posted by ehall
You know sadly, I have been. Twice. So no I'm not. (ergo USMC ret.) However, and more sadly, the theft of Rolex's car got me thinking about what amount of specific info I share with others on the web. There is a strong chance, though no one has any proof, that information about his car, his garage, (there were pics posted,) and info culled from his web site, may very well have made him the target for the theft of his rather public car.
WOW! I'd be to easy a target! I can be "defeated" much, to easily!
You WOULDN'T HAVE to result to such devious tactics!
Originally Posted by leonc944
Where can I get a good ground strap?
Hosrom and MPD47, do you guys mind measuring the length of the two ground lines coming from the battery connection? I wonder if Dan chopped the length down any bit to create a shorter path.
