re-assembly of power steering rack - lube for rack and pinion
Old 01-09-2006 | 04:00 PM
500's Avatar
500
Default re-assembly of power steering rack - lube for rack and pinion
Well, after finally finding a nice tower to replace the one I damaged, I'm ready to put the power steering rack back together. I'm using the Rennbay kit.
Everything should go smooth, my question right now though, is: What is the right/best lubricant to use for the rack teeth, the pinion and the spring loaded pressure block? I.e. all the parts that are not normally bathed in a flow of power steering fluid?
The residue on these parts when I disassembled the rack almost looked like engine assembly lube?
Thanks for looking!
Old 01-09-2006 | 04:14 PM
Zero10's Avatar
Zero10
I thought those parts had ATF on them?... uh oh
I used wheel bearing grease on most parts of my rack upon reassembly. In particular, I used Redline CV-2.
No problems yet.
Old 01-09-2006 | 05:28 PM
JET951's Avatar
JET951
yep wheel bearing grease is the way to go. we do hundreds of rack overhauls and always use bearing gease. never had a problem
