Ahhh Cheeseheads.... (No, not Green Bay Fans)
Originally Posted by hosrom_951
Like i mentioned before, i took off all four CV bolts numerous of times and reused them without any issues at all.
One thought: You can buy bendable star shaped washers with a saftey wire hole in them. These are used with hex heads, once torqued the washer is bent to hold the head and saftey wired to an adjacent bolt.
vis:
http://www.aircraftspruce.com/catalo...ywirekits1.php
-Joel.
vis:
-Joel.
Originally Posted by wizkid918
if the cheesehead bolts are indeed stretch bolts, that probably means i should replace all the flywheel bolts then? they looked brand new, but if they have already been stretched... mine as well spend the 15-20$ and just get new ones
