TDC: Methods of locating TDC contradict each other??
I'm doing my headgasket (again...don't ask). I've got the head off.
Before I took it all apart, I found TDC (instructions @ Clark's Garage) using the 5mm window on the bell housing under the car, and verified TDC with the timing mark on the camshaft timing gear.
Looking at the #1 cyl., if I remove the flywheel lock and turn the crankshaft, the piston still has a 1/4" of travel to make in the upward direction, meaning #1 is not in TDC when the cam and flywheel say that it is.
Should I put it at TDC visually, by looking at the piston come ALL the way up, or should I put it at "TDC" according to the marks?
I always put it TDC by using a dowl (long scredriver). I stop rotating as soon as the piston stops rising (remeber that there is a couple of degrees of rotation where the pistion remains at TDC). I always line the cam up with the mark as it always ends up within half a tooth of TDC.
That is not possible unless the flywheel is improperly installed, which is difficult to do to say the least. TDC means piston #1 at TOP dead center. Every other marker is irrevelant. Other than than #1 piston at top means you will most likely be bending valves. Take a picture. If your flywheel is installed improperly, the last time you installed the head would have bent valves so check your head for valve damage.
Hey Man
I thought that my TDC cam mark didn't line up with the one in the bellhousing window either. Then I actually got right on top and looked at the opening square on and it was within half a tooth on the cam mark. It looked way off when looking at an angle from the fender though. The mark on the bottom of my flywheel is very hard to see and I ignore it.
Well, I may or may not have bent some valves the first time around, but it doesn't matter too much to me now, because I bought another head w/ valves already installed and am using it this time instead, so no extra loss here.
Instead of using the window on the bottom of the bell housing, I checked the top of the bell housing with the "OT" line, and it is in the right spot when I put cyl #1 at TDC, and my balance shaft sprocket agrees with this as well, so that is where I will leave it when I re-install the cam tower.
Very weird. I noticed last time I had my early '85's belts off that the "OT" mark visible from above was correct (lined up with the TDC using the "stick" method and the cam gear mark, etc.) However the mark that's usually on the flywheel visible from BELOW wasn't there. Weird. Maybe the PO machined it off by accident? I looked long and hard and I'm sure it ain't there.
Addic
The flywheel has a pin and if someone broke the pin or removed it, it can be installed improperly. That is why I stated it is difficult to do to say the least. I thought he meant the OTC timing mark on the top was not "on" when the piston is at TDC. I never go by the bottom and didn't even know they have instructions to look for a mark that is not there.
and my balance shaft sprocket agrees with this as well...
And remember, you have to be looking at the OT from directly over it, not at an angle, to watch for the stripe lining up with the black needle inside the opening.
If you need a hand, throw up a post. Sounds like you live nearby.
