TDC: Methods of locating TDC contradict each other??
Originally Posted by Hawk36
When turning the engine to find TDC, which direction to you turn when facing the engine? Does it matter?
Jane Bond 007
I don't have the bottom mark either. With the cam tower off, you can just put the piston at TDC. There is no way to mess it up b/c the crank turns twice for every one turn of the cam. TDC is only different from the exhaust stroke once the belts are on.
Originally Posted by URIN 2ND
If you need a hand, throw up a post. Sounds like you live nearby.
I set TDC easily w/ looking at the piston itself, since the head was off. My OT line and balance sprocket marks agree with it, so I went ahead and put it back together... My car runs!!! No leaks, and with the new vacuum and fuel lines, plugs, and a top end free of carbon build up, it runs like a CHAMP! Oh man does it sound good too, now that I don't have an exhaust leak making my bad cat sound really loud. Thats on the to-do list too.
edit: I'll probably post another thread when I get home from work, with some details of the project, and pictures of my much nicer looking engine bay.
UAE Rennlist Ambassador
Originally Posted by Legoland951
That is not possible unless the flywheel is improperly installed, which is difficult to do to say the least
I use a long screw driver, as Daniel does.
