Front Turn Signal Doesn't Blink.....
for some reason the driver side front turn signal doesn't blink but the other turn signal work, i've change bulb...whatelse? relay? bad ground?
TIA
TIA
I recently had a problem with my turnsignals intermittently working...Id start the car up and be driving for a bit, and then the turnsignals would stop blinking and just stay on.
I replaced the relay and solved my problems.
If the light doesn't even come on, I would say check the wiring to that light.
Nerd Herder
Grounds, my dear friend. Clean the grounds in the headlight buckets as a start/ ALSO- make sure ALL the left side bulbs are good. (side markers, rear lights etc)
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Just a thought: I once replaced the turn signal with the wrong bulb (used 1156 bulb instead of 1157) which resulted in non-blink. IIRC, 1156 has the two nodes directly opposite of each other, but the 1157 has the two nodes set slightly offset -- but otherwise, the two are of identical size.
Originally Posted by 944TTwin
The amber light works, it's just when i turn on the blinker it doesn't blink
You can get a $25 generic VW-type flasher relay from an import auto parts store. Should be an easy fix.
