Downforce
#46
Originally Posted by Rich Sandor
and GEO, I have to disagree, most cars, except for sports cars, generate lift, not downforce.
#47
Everyone knows that if you increase downforce, you also increase drag.
What you state is generally true, but you should not make such general statements as absolutes.
#48
There are different types of drag. You would be more correct in stating an increase in downforce increases rolling resistance (friction) which can be independent of aerodynamic drag (a whole other set of factors).
#49
Originally Posted by streckfu's951
If you are producing lift, your force is represented to the right of 0. To ask "is the reduction of lift the same as downforce", the answer is no as it is only less lift. Say you start with a value of 5 Lift. By adding a splitter and spoiler, you reduce that force by 3. Now you have a value of 2 Lift.
This is all a numbers example. In reality, I agree with you Geo, that almost all cars generate downforce.
Splitters reduce the air traveling under the car which becomes turbulent and really messes with the cars stability.
Take a look at the shape of F1 cars. The wings are all shaped to push down on the car. They are all curved upward to use the same deflective force Shiners describe (which is not the same principles that describe aircraft wings). Also, the underside of F1 cars is convex to act like an inverted wing.
This is an interesting thread. I'm certainly learning some new things. I'm reading some of the links and some of the links they provide. This is a real learning opportunity.
#50
or Sam O
Geo and steckfu are mostly correct. Spoilers are used to simply to incease downforce or negative lift on the top of the car. However, they significantly increase drag because they cause a large seperation in the boundary layer. (you want the smallest possible boundary layer thickness. Within the boundary layer the fluid is more viscous than outside which equates to larger shear stresses and drag forces).
Now, air dams or splitters can be used in two ways. One is used to create a venturi effect where flow under the car essentially sucks the car to the road and increases with speed. The second method has to do with the underbody design. When done correcty the drag is decreased and with a velocity increase, it can also reduce lift
#51
So much (dis-)information.
Airfoils don't just use a planing effect to create lift. If that were true then the engines of the aircraft would need to produce the same force as the lift. The trick is that the airfoil produces force but as the plane is moving (mainly) forwards and not up, there's no work done and no power consumed. Pretty cool, actually.
Compare a spltter system to a ground effects system. What's been learned is that you can create downforce by using aerodynamics under the car and reduce drag by letting the air flow both over and under. Again, pretty cool.
A splitter increases the drag on the car by forcing all of the air up-and-over the car. This moves the air from ground-level a long way and that requires more power. It creates down-force by inducing a slight vacuum underneath. Nice, but not ground-effects cool.
A typical car (e.g., 944) will have downforce on the front due to air impacting the sloping hood and windshield. The there'll be lift as the fast moving air over the roof and tail created by airfoil-style lift along with lift from lower pressure air over the rear.
Ahhh, Fun!
(No resonance effects. Still waiting for that white paper.)
Ahhh, Fun!
#52
Geo: thanks for correcting me. you are right. Since I have an aviation background, I apply a lot of that here. Thing is, the ground doesn't usually play a role (other than takeoff/landing) when talking about lift and drag on an airplance. Hence my sweeping generalisation.
#54
Here is a clip from a Racecar Engineering article on splitters than I scanned for a friend of mine last year.
#55
What spoilers actually try to do is keep the airflow attached. This includes rear spoilers (not wings) and even the so-called "dive-planes" you see on many sports cars.
Front spoilers reduce the air flow under the car (if they are any good at all).
#56
The duck tail on a 911RS is a perfect example of a spoiler.. it SPOILS the downward flowing air and prevents lift on the car. It doesn't actually create downforce though.
A "spoiler" on the front of a car is actually incorrect terminolgly. It should be called a splitter or an airdam, or a wing, but not a spoiler.
#58
Glen, I'm surprised that someone who can write so much about aero would have that "parachute" for a rear valence installed on thier car.
#59
Ahhh, Fun!
Ahhh, Fun!
