Where is the Reference Sensor on a 944S?
Old 12-15-2005 | 03:55 PM
Operator's Avatar
Operator
Default Where is the Reference Sensor on a 944S?
I did a search, can't find much info about it.
Reason I ask is because I found an old thread where someone mentioned that their Reference Sensor on a 944S was causing their idle/stumble/stalling problems.
Can someone show me a visual reference as to where it is?
Old 12-15-2005 | 05:37 PM
7thStranger's Avatar
7thStranger
It's on top of the bell housing.
Find the black plug between the intake and firewall. Follow it down.
You may have to remove the intake manifold to replace it.
It is located at the same place as the 8 valve cars.
Old 12-15-2005 | 08:36 PM
Fishey's Avatar
Fishey
There is only 1 sensor on the 16v cars unlike 2 for the 8v's...
If you still need help I can post up some pictures since mine right now has what you call "Easy Access"
Old 12-15-2005 | 10:00 PM
Operator's Avatar
Operator
that'd be swell Fishey
Old 12-15-2005 | 10:21 PM
tod84944's Avatar
tod84944
The ing. module is located behind the drivers side head light.
Old 12-15-2005 | 10:53 PM
triscadek's Avatar
triscadek
Have you checked the AFM? That's why my S does that.
http://www.frwilk.com/944dme/afm.htm
Old 12-15-2005 | 11:10 PM
jonnybgood's Avatar
jonnybgood
Tod, that is the ingition control module, he is asking about the reference sensor.
The reference sensor can cause the stumbling you are talking about. Other causes are vacuum leaks, throttle position sensor and the idle stablizer valve.
Old 12-15-2005 | 11:14 PM
gtroth's Avatar
gtroth
Not sure that sensor will cause idle problems, Operator (cut-outs/stumbling, yes). If you want to go after it I think you will have to remove the intake manifold (as you may know, I was just there). You might consider running though the DME Diagnosis / Troubleshooting section in FSM.
Old 12-15-2005 | 11:22 PM
jonnybgood's Avatar
jonnybgood
Yeah, seems like the if the ref sensor was bad you would be having problems all the time.
Old 12-16-2005 | 01:10 AM
Fishey's Avatar
Fishey
Here is a picture of the location + braket (sensor has been removed)
Also here is an obviously bad sensor
Here is what a good sensor looks like
Here is more information then you ever need to know about them.
http://www.clarks-garage.com/shop-manual/ign-02.htm
Hope, that is helps
Old 12-16-2005 | 02:00 PM
Operator's Avatar
Operator
awesome Fishey.. but how do you get to where that picture is taken? Clarks says its behind the engine on the clutch housing... how the heck does one get there?
Should I just have it checked/replaced when I get my clutch done (probably soon)?
Old 12-16-2005 | 05:46 PM
7thStranger
You will need to remove the intake manifold.
I agree with the others, sounds more like the Air Flow Meter or a vacume leak.
Old 12-16-2005 | 07:06 PM
Fishey's Avatar
Fishey
No reason to remove manifold to get to the bolt.
My manifold is removed but its does not need to be removed to pull the sensor.
P.S. The yellow thing is the "oil fill cap" for referace!
Old 12-17-2005 | 11:36 AM
gtroth's Avatar
gtroth
Is that an S we're looking at there, Fishey?
Quick Reply: Where is the Reference Sensor on a 944S?
