manual steering?
have a complete 80 924 turbo. will the steering rack, fit and what will it take to put in a 944S?how much hp increase, is it enough to justify swap?
Keep in mind that your car is a late-offset car, so that even if you get the early 924 rack to fit, or purchase a 944 rack, you will need the special ($$$) late-offset tie rods.
There is no "increase" in HP with this mod, most people do it for better road feel/response, and to eliminate a leaky PS system. The elimination of the PS pulley will probably reduce some parasitic drag on the motor, and the lighter weight manual set-up will be less weight to haul around. But don't do it if getting more HP is your main concern.
Nerd Herder
Jeeezzes Marty.. What you cookin up now?? DONT change your car dude- it's PERFECT!
Tifo is absolutely correct.
So- why not resurrect the 931? you have the tools dude..
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Originally Posted by tifosiman
Won't fit without a lot of work. The crossmembers are different, as are the mounting points. I *think* someone on this forum did it a few years back, but I don't recall the amount of work or what he did.
Originally Posted by Manning
Travis came up with a simple solution to avoid the issue of finding the late offset manual tie rods. Use the early offset manual tie rods, a short section of metric threaded rod and then the outer ends from a power steer tie rod. The threaded rod allows you to use the more common power steering ends as well as making up the lenght difference.
Yeah, good point. If I had the need I would try it just to see. I'm kind of funny like that. I love trying out ideas and devices, even if I have no need for them, just to see how they work. I need a gig as a product reviewer for a magazine.
