Help in Seattle!!!
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
So I am visiting Seattle for the holiday's and I have an emergency, I hope someone can help me.
I lost the crank bolt on the front of my engine! I was lucky and didn't lose oil pressure and I didn't even lose the power steering pulley. But if someone in the Bothell area has a crank bolt they can bring me, I will compensate them. I know I can try Porsche on friday, but I don't want to chance them not having the bolt and washer.
I have a place to do the work, and tools, but I don't have the parts. If anyone has the bolt, washer and, just in case, the power steering pulley that they will let go of for a decent price, or I can ship you the parts off my spare engine at home, please pm me.. I did check the part numbers, and it is the same part from 86 on.
Thanks,
Tom
Hmm, my sig hasn't been working, but this is a 89 S2. A 89 Blue S2, to be exact...
Thanks again!
Thanks,
Tom
Thanks again!
is the crank held on by that bolt?
or are there other smaller bolts that hold it on?
cause I wanted to remove my p/s pulley and the nut if I didn't need them
I'm in bellevue
I'm in bellevue
Tom,
PM me for my phone number. I have the bolt and washer. The pwr steering pulley, I'm not to sure, I'll bring the extra ones I have.
The parts you need, are these, correct?
The bolt : M16 X 1.5 X 60
Washer: 944.102.210.02
Pulley: 944.102.214.03
Ken
Whatya know, I've got that pulley too! The .02 AND the .03.
Ken
I'm in bellevue
I'm in bellevue
(By the way Tom I do have the torque wrench and flywheel lock, if needed)
The smaller, 6mm bolts are holding the 6 ribbed ac/alt. belt pulley to the balance shaft drive gear behind the pwr. steering pully. You won't have to remove those, but do check that they are intact and torqued when your there.
Nut? what nut are you referring to?.........ME?
Granite Falls is not that far from Bothell. Kinda out in the country (yeah, like that really exists out here any more ) ya know.
Originally Posted by Granite 944
Granite Falls is not that far from Bothell. Kinda out in the country (yeah, like that really exists out here any more ) ya know. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
