Headlight rubber trim piece...how does this go back on?
I picked up the vented nose panel from my buddies body shop earlier today and mounted it up earlier. Took about 2 hours of work...mostly because i didnt think so much of the rear support for the panel needed to be cut off! Anyway, there are these rubber pieces that squeeze under the nose panel, they cover up the two bolts on each side. I took them out (they just pull out with a bit of force) however i cant figure out how to get them back in. Any ideas?
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201987%20Porsche%20944/931%20Vented%20Nose%20Panel/IMG_2311.jpg)
The panel is mounted up, however no pictures yet. Maybe later tonight. I took a bunch of pictures while mounting it up so i can do a write up on how its done, will post later tonight.
Jon, I THINK that the one in your pic is actually upside down and belongs on the other side. The recess in the upper half of the piece as shown in the pic is where the ends of the two studs will nestle. I believe you can actually see the marks in the picture that the two studs left as the piece was pulled out.
You have to just push them in. A little soapy water might also help.
Allan you are probably right, i should have noted the orientation of these buggers before i pulled them out, but like any job i neglected to do so
. Will attempt the soapy water trick tomorrow when i squeeze these damn things back in...thanks!
Cast Iron Man
