OPRV tight?
Originally Posted by Charlie
Ken,
I agree, there is probably 2 O-rings, one at the top and one at the bottom. Having never had mine apart I have not seen the bottom one.
I'm curious, how do you take it apart and but it back together. When I was having oil pressure problems I took mine out several times, it all came out as one piece.
I wonder if Jeff's is all one piece.
I've also noticed that no one ever talks about the bushing that fits into the engine block that these OPRV's slide into. I also know from TSB's and the FSM, that it is VERY important that this bushing is seated fully into the block, and not loose, as a low/no oil pressure condition could and can result if not followed.
"I really cant remember now if the begining of the threads were tapered. I hope they didnt send me the wrong valve. Would this be causeing the resistance? The part number on the bag was correct, but I guess that doesnt mean much does it. Well see. Thanks for the replys."
Well, is it installed, so ya can't look at it anymore? If it is installed, then it probably was the correct one.
-Jeff
