944 diet plan
Originally Posted by evil 944t
I don't fully agree with that spreadsheet. Out of the 4 wheel wells, the driver/passenger/trunk/doors, I scrapped off 25lbs total. That was 2 days of work too.
just to note my A/C system (compressor, condenser and the radiator thing) along with hoses and bolts weighted in at 31 LB
the system was empty, maybe that has an effect.
Well here's my spreadsheet showing all the deletions to my car. Note this was not done to any rules / specs so proceed at your own discretion.
1989 944 S2 Stock Car Weight ( 1/2 fuel & no driver)
Totals
Left Front 735 Right Front 738 1473 49.9%
Left Rear 705 Right Rear 772 1477 50.1%
Total Original Car 2950 #
Reductions / Additions Completed
Remove L & R Rear side carpets w/ shoulder belts & Rear Cargo carpet -21
Remove Rear Upper Seat back rest -24
Remove Spare Tire & Tools -38
Remove rear wiper motor & wiper -3
Remove center console, radio bracket & door speakers -8
Remove sunroof motor & gears -6
Remove side roof padding between A & C pillars -2
remove rear seat side trim -4
Remove front floor carpet & insulation -15
remove rear lower seat -5
Switch to FG sunroof -3
Remove cruise control module & wiring -3
Switch to racing seats (Car weighed 2740 w/ 3/4 tank, not 2768 est.) -50
Remove additional sprayed in insulation -14
Replace aluminum lugs w/ steel 2
Install rear tow hooks 2
Remove door glass and motors -28
Add roll cage 100
Delete headlights & motor -20
Replace exhaust system -17
Remove lower bat wing & replace with lip spoiler 0
Remove suspension including rear torsion bars & replace w/
Leda Coilovers (450#) on all 4 corners w/ camber plates
Reweigh Car w/ 1/2 tank of gas & 190# Driver
Left Front 753 Right Front 740 50.80%
Left Rear 722 Right Rear 723 49.20%
Total weight w/ driver & 1/2 Tank 2938 #
Total weight w/ 1/2 Tank 2748 #
Total weight Dry 2688 #
Totals
Add roll cage 100
