Oh no! I need a cooling fan switch wiring harness!
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
funny I had checked the battery and wires around the firewall for any frays this morning too. Obviously I really can't make a solid judgement as to whether any wires from the battery are the problem or not. What areas would you recommend I test with the multimeter? My guess is still the possiblity of a fan failure.
This morning the fans were coming on still around normal temperature they should.....both of them. The fuse hasn't been fried yet. I had also noticed that the area inside the fuse appears to have some melted plastic around it. Very odd. Definitely some over-voltage going on in block #15 here....
Fuse 24 Assassin
Fuse 24 Assassin
Originally Posted by Dilberto
Andy- you have system shorts, stemming from either the alternator, startor, or coil. Since these three components tie into the battery- juice to the fan switch is ordered by the sender, located between cylinders one and two. It appears the ground is your problem. Break out that DMMS again!
Andy, I have another wiring harness too- if you really need one. $30 shipped and its yours. PM me if wanting it.
Zach
Zach
Zach
Zach
