Steering shakes severely over bumps
OK - I had the same symptoms. I bought the car back in NJ years ago - it was basically undriveable - if you turned left at highway speeds it would start shaking and jumping around like crazy. I bought the parts, replaced what I could in the parking lot - it had poly bushings that were hammered oval, I replaced all those with rubber, replaced the tie rod ends, and got it to stop freaking out but it still did the steering wheel shake thing on hard bumps. Rat a tat tat. Drove it back to Washington when the NY job was done, and it's been sitting waiting for love for the last few years.
Thanks to COVID I've had time to wake it back up again - spent money on new tires and a battery, fixed a bunch of little things (wiring, shifter linkage, thermostat, etc), and finally installed the new struts! HOLY CRAP what a difference. The left strut still had a little life in it, but the right one was completely gone. No resistance whatsoever. As described, I was feeling the dynamics of an undamped spring. It is amazing how well it drove anyway, without any damping at all.
I had some serious issues getting the old inserts out - the previous mechanic put silicone on the bottom of the inserts before stuffing them in, so getting them out totally sucked. They were glued in solid. The shocks pulled apart instead of coming out, leaving the shell of the old shock stuck inside ... I got one out from the top, bending it in and gripping it with vice grips and prying with a screwdriver ... over and over until it loosened. The other one just broke. I had to drill a hole in the bottom of the strut to poke out the remains with a punch. That did the trick and would have saved a ton of time if I'd thought of that first. Anyway. It is so much better! Now the car rides smooth, is quiet over bumps, and the only play left is in the steering rack itself. Which will be next. But first, I've got some country roads to enjoy - snow is gone, cops are busy, don't have the virus yet, better enjoy it while I can! LOL.
h011yw00d (04-10-2020)
Couldn't agree more! Bounced the rev limiter today from 2nd to 3rd ... so that's a good sign. All systems go... except AC, cruise control, and the hatch kinks & unlocks one side instead of both from the button, probably needs more subwoofer. But at least the button does something! That is an improvement.
Sure is fun working on the 944! Had my 13 yr old daughter help me bleed the brakes and that was awesome. Took my wife out for a cruise and then made out like teenagers. Good times
