Cutting headliner to get at sunroof gears
Originally Posted by 944J
I did mine a couple years ago and I seem to remember the gears being metal. Is this possible?
What's 3m snot tape?
Snot tape is 3M Adhesive Transfer Tape #924
http://products3.3m.com/catalog/us/e...er/output_html
VW uses the stuff to attach the plastic vapor barrier to the inside of the metal door frame before the door panels goes on. Waterproof and sticks like snot. Think of it as industrial rubber cement on a roll. Find at your local art supply store.
Good luck.
Originally Posted by jjjr944
OEM gears are white plastic/nylon, so that if they bind, they strip the plastic gear teeth and NOT damage the wire cable drive as that is a real PITA to repair. A few aftermarket suppliers stock the metal gears, but if your sunroof clutch is set correctly, the plastic gears work just fine-a-roony.
Good luck.
Good luck.
Good luck.
Good luck.
Inspection of the lifting arms shows that the grease has baked into the housing and dried up possibly causing the arm to stay "glued" in place just long enough to strip a few teeth. Thinking of replacing the arms as one of them is fairly worn on the bottom.
After 3 tries of adjusting the arms by counting teeth, found that setting the motor to arms retracted fully position and then placing the arms in flush worked fairly well.
Originally Posted by 944S2IFISH2
So... What kind of grease/lube stuff do you put on the plastic gears?
TIA
TIA
