Rear Balance Shaft Seal Replacement?
My upper balance shaft rear seal is leaking. Can this seal be replaced without taking the balance shaft cover off? Thanks in advance.
Nope;
It is an o-ring seal on an alloy disc. You've got to take the cover off. I would just clean the area well and silicone it if I were you. Not worth the trouble to get to it, let alone pull all that apart.
