Lamp Replacement
Lamp Replacement
Can anyone advise what is involved in replacing a lamp in the instrument cluster? The car is a 1987 944 with oval dash. I am concerned that I may need to removed the whole of the inside of the car, and with my luck it will never go back again!
Many thanks
Mike
Many thanks
Mike
UAE Rennlist Ambassador
You have a LAMP in a car?
Anyways, you need to remove the gauge cluster
Looks like a lot, but very simple and straigh forward, should take you 30 mins on average
Cliff: I tried several times, just couldn't have enough clearance without braking the plastic trim surrounding the steering coloumn.
It can be done without removing the wheel but it requires some questionable twisting and turning. It should however be possible to lower the wheel a bit by disconnecting the column under the dash.
You will also want to disconnect your battery for a while beforehand or you will run the risk of getting an airbag fault, if you have airbags.
If you want brighter gauges, now would be the time to resilver the light conduits and replace the old bulbs with new ones. However do not put overwattage bulbs in place of the gauge lamps, they will melt the plastic sockets.
OK, end to the debate. Some of the late cars have the wheel with about a 1" spacer. I pulled one with the wheel on. Another I couldn't figure out why it wouldn't fit, I was going nuts, done it before, what's the problem, lol.
Based on my experiences, you could pull the gauge cluster out without removaling the steering wheel on both late and early style interiors. However i find its much easier to just take it out. The extra 3-4 minutes it takes saves alot of trouble having to slide the cluster out between the dash and wheel. The early cars really didnt have a cluster so to speak...just 3 seperate gauges.
The steering wheel is held on by one large 24mm or 15/16'' nut. The same size as the crank pulley. Just park with the wheels straight and pull the wheel off. Makes life alot easier.
