Optimal Camber for Snow?
I have adjustable camber plates in my N/A that sees regular snow duty, and I was wondering what kind of tradeoffs I should expect with adjusting front camber.
When I drove my 924S in the snow I ran with stock settings and had no problem.
The fun started however when I drove for part of a winter with blown shocks and upper bearings, which would allow radical dynamic camber changes in corners. Not even close to being fun, let me tell ya.
Just a car guy
As a good starting point - figure about half the negative camber you would run on a 'wet' setup (or maybe 25% of a dry setup). Tire tread pattern and compound will be the biggest contributing factor to traction in snow. Small camber angles will just be a helpful contributor.
I was able to keep the track/street set-up on my 944 (maybe 2 F and 1.5 rear) and run the car with snows. Since you have the quickly adjustable set-up, I would agree that something in the "stock" range would likely be best.
My track settings with winter tires on the 968, that's a different story. Drivable, but more of a full-time rally-car experience. Not fun.
